It is currently Tue Nov 17, 2026 2:39 am
PostPosted: Sat Nov 08, 2008 3:15 pm
i am planning on installing a nitrous system when i build my 6 this winter, and im not sure wether i should use a fogger or a plate system. The engine will be carburated
PostPosted: Sat Nov 08, 2008 3:36 pm
Can we assume you're running a 4bbl? It it oriented N-S or E-W? If the carb is mounted with the primaries toward the front of the car a nitrous plate under that carb is going to spray a lot of N2O and fuel on the outside wall of the plenum.
PostPosted: Sat Nov 08, 2008 3:49 pm
ya im running a 4 bbl, it will probley be a 390cfm holley 4150. i was planning on installing it e-w, for better fuel distribution, but i wasnt sure if i should have the primarys towards the left or right side of the car
PostPosted: Sat Nov 08, 2008 4:01 pm
For my '67 Valiant I'm running my 390 Holley's primaries toward the driver's side on an Offy manifold. The distribution appears to be pretty good oriented this way. When I had the carb this way on an unheated Clifford manifold the end cylinders were rich er than the middle cylinders. The next car is getting a Clifford manifold with a plenum divider and nitrous. I may try the primaries toward the passenger's side. I'll need a longer throttle cable, but this will rotate the Edelbrock carb so the fuel inlet is to the driver's side where the factory fuel lines end on this chassis.
PostPosted: Sat Nov 08, 2008 5:46 pm
99% of the time a plate will meet your needs.
Carb orientation is basically irrelevant. :shock:
PostPosted: Sun Nov 09, 2008 6:49 pm
SSRN National Champion
Damn I love it when Bagel gives a correct answer. Makes me think im not a total idiot. Possum :D
Any More Bees Want To Get Smoked
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
