exhaust
https://slantsix.org/forum/viewtopic.php?t=32126
Author:  jason white [ Fri Nov 07, 2008 4:51 pm ]
Post subject:  exhaust
I would like to know the best setup for dual exhaust on my 1987 D150 keeping in mind I want good sound and performance on a tight budget any help would be appreciated
Author:  SlantSixDan [ Fri Nov 07, 2008 5:07 pm ]
How tight is your budget? There is no sense in doing anything dual if you're going to keep the single-outlet stock exhaust manifolds. If your budget will cover it (plus the necessary pipework), get Dutra Duals.
Author:  lincparts [ Fri Nov 07, 2008 5:42 pm ]
Post subject:  2 1/4 "
a 2 1/4" single is good enough for any non race build, and cheaper too ..
Author:  jason white [ Mon Nov 10, 2008 8:54 pm ]
thanks guys I appreciate the tips I eventually want to get a set of truck headers and 4brl
Author:  DusterIdiot [ Mon Nov 10, 2008 9:38 pm ]
Post subject:  Hmmm...
1987 should already have the 2 1/4" pipe... which is there to make up for that nasty late model setup where they used a small cat. convertor to hook to the AIR, then a few feet down they used the standard Cat. convertor to make sure that a) it passed emissions... then b) strangled the $^%&^ out of it...
Check your local laws... if no inspection/smog check just getting the old original cats out of there will help loads... if you have to smog... finding a nice cat-back with a larger input/output pipe size and using a suitable pipe setup will help keep you in check, and keep your power up.... (make sure tune up and carb are in good shape...)
Author:  jason white [ Tue Nov 11, 2008 8:42 pm ]
no kidding they did a good job of choking the crap out of them the V8 guys had to deal with three of the cats
Author:  72Duster08 [ Tue Nov 11, 2008 9:23 pm ]
Heres my exhaust that was around $100 for parts and labor. Its 2.5" piping with a single cherry bomb. the cherry bomb is only $20. asuming this is the sound you want?--->
http://www.youtube.com/watch?v=bUcZCHH7Trc
Just an idea for you
Author:  jason white [ Wed Nov 12, 2008 3:16 am ]
that is great sound and that is what I was looking for thanks that is a beautiful duster you have
