| nitrous: fogger or plate? https://slantsix.org/forum/viewtopic.php?t=32157 |
| Author: | darrt wells [ Sat Nov 08, 2008 3:15 pm ] |
| Post subject: | nitrous: fogger or plate? |
i am planning on installing a nitrous system when i build my 6 this winter, and im not sure wether i should use a fogger or a plate system. The engine will be carburated |
| Author: | Joshie225 [ Sat Nov 08, 2008 3:36 pm ] |
Can we assume you're running a 4bbl? It it oriented N-S or E-W? If the carb is mounted with the primaries toward the front of the car a nitrous plate under that carb is going to spray a lot of N2O and fuel on the outside wall of the plenum. |
| Author: | darrt wells [ Sat Nov 08, 2008 3:49 pm ] |
ya im running a 4 bbl, it will probley be a 390cfm holley 4150. i was planning on installing it e-w, for better fuel distribution, but i wasnt sure if i should have the primarys towards the left or right side of the car |
| Author: | Joshie225 [ Sat Nov 08, 2008 4:01 pm ] |
For my '67 Valiant I'm running my 390 Holley's primaries toward the driver's side on an Offy manifold. The distribution appears to be pretty good oriented this way. When I had the carb this way on an unheated Clifford manifold the end cylinders were rich er than the middle cylinders. The next car is getting a Clifford manifold with a plenum divider and nitrous. I may try the primaries toward the passenger's side. I'll need a longer throttle cable, but this will rotate the Edelbrock carb so the fuel inlet is to the driver's side where the factory fuel lines end on this chassis. |
| Author: | slantzilla [ Sat Nov 08, 2008 5:46 pm ] |
99% of the time a plate will meet your needs. Carb orientation is basically irrelevant. |
| Author: | Ron Parker [ Sun Nov 09, 2008 6:49 pm ] |
Damn I love it when Bagel gives a correct answer. Makes me think im not a total idiot. Possum Any More Bees Want To Get Smoked |
