It is currently Fri Nov 20, 2026 4:16 pm
PostPosted: Tue Sep 20, 2016 11:48 am
I have a proper super 6 BBD that had a bunch of bad pieces from corrosion, and a '71 318 BBD that was really nice. I rebuilt the '71, only to fight the drilled plates and loose shaft. The super 6 BBD has a good, tight shaft and undrilled plates. Can I swap the lower plates?
PostPosted: Tue Jan 24, 2017 8:39 pm
Bump...
...and to be clear, I'm taking about wanting to swap the entire lower plate assembly, not just the 2 butterflies...
Thanks!
PostPosted: Tue Jan 24, 2017 9:32 pm
As long as you are absolutely positive that all the passages in the castings line up, go for it.
Users browsing this forum: Google [Bot] and 7 guests
