| Dampers https://slantsix.org/forum/viewtopic.php?t=32175 |
| Author: | 68barracuda [ Sun Nov 09, 2008 12:09 pm ] |
| Post subject: | Dampers |
OK another fiction or not question Is it true that you can use a RB damper on a slant? apparently the crank nose an those V8's and the slant is the same |
| Author: | DusterIdiot [ Sun Nov 09, 2008 1:00 pm ] |
| Post subject: | Yes |
Yes you can use the B/RB harmonic balancer. of course your on your own for a timing mark... -D.Idiot |
| Author: | Charrlie_S [ Sun Nov 09, 2008 1:50 pm ] |
Also, the pulleys will not line up. |
| Author: | Dart270 [ Mon Nov 10, 2008 3:28 am ] |
I would try to get a Romac Slant 6 balancer from Oz. Nice unit, not too expensive, and endorsed by Cameron Tilley... Lou |
| Author: | walpolla [ Mon Nov 10, 2008 7:27 am ] |
http://www.romac.com.au/ 0224 or 0224SA,depending on your want. good stuff. regards Rod |
| Author: | terrylittlejohn [ Mon Nov 10, 2008 8:43 am ] |
bb dampers work but you have to change the timing cover seal to a bb seal and with the belt groove have one machined into the thick part of the damper and you can use the stock belt locations |
| Author: | MichaelS [ Mon Nov 10, 2008 12:15 pm ] |
Do all slants come with dampers? Mine is a '74 I didn't think it had one but I could be wrong. What is the advantage of adding one if it dosent? |
| Author: | SlantSixDan [ Mon Nov 10, 2008 12:41 pm ] |
All engines have vibration dampers, including all slant-6s, including your '74. It is integral with the crankshaft pulley. |
| Author: | 68barracuda [ Mon Nov 10, 2008 12:58 pm ] |
WHY I asked this question - 1 RB dampers are easy to get over here slanties not 2 I was wondering how to eliminate the dreaded outer ring slip This said - the romac units are nice Just wonder which will be best - the steel or ally outer ring |
| Author: | SlantSixDan [ Mon Nov 10, 2008 1:05 pm ] |
There's no need to eliminate the inner-hub/outer-ring construction. They work fine for decades! |
| Author: | MichaelS [ Mon Nov 10, 2008 2:25 pm ] |
Thanks Dan, sometimes its better to ask the dumb questions than to remain ignorant. |
| Author: | 6shotvanner [ Mon Nov 10, 2008 7:37 pm ] |
As long as we're talkin dampers,Hows come my 80&83 truck slants have such a BIG weight compared to others I see?Does that have to do with the lighter crank(13-14# less)?If so what happens when swapping older/newer balancers on older/newer cranks?Just another question that keeps me awake at night |
| Author: | THOR [ Mon Nov 10, 2008 7:39 pm ] |
I have a cast crank engine with a standard damper on it.. I suppose it is possible that since yours is a truck engine, that they put maybe a V8 damper on there? ~THOR~ |
| Author: | SlantSixDan [ Mon Nov 10, 2008 7:50 pm ] |
No. Slant-6 engines always and only got slant-6 dampers. V8 engines always and only got V8 dampers. |
