Thinking of picking this up.
https://slantsix.org/forum/viewtopic.php?t=32197
Author:  MindforRent [ Mon Nov 10, 2008 7:46 pm ]
Post subject:  Thinking of picking this up.
I saw this ad on CL and I'm going to ask him to send me some pictures of the k-member and attached disc brake parts. Any ball park as to what I should offer him for it. I'll pick up the wheels as well.
Now all I have to do is convince my wife its a good idea.
Author:  daniel_depetro [ Tue Nov 11, 2008 4:29 pm ]
$250.00
Author:  zorg [ Tue Nov 11, 2008 7:53 pm ]
Just to give you an idea, I just paid $550 for the whole disk set up (upper/lower control arms w/ sway bar tabs, spindles, rotors, calipers, all new high quality bearings and bushings for the whole front end) a 7 1/4 rear with big bolt pattern, factory rear sway bar and all new mounting hardware, and a set of Magnum 500s. I might be forgetting something... Oh, and I hauled it all 4 hours home in my Dart!
Author:  Brian [ Wed Nov 12, 2008 6:29 am ]
If you can get the setup for under $200 that would be ok. Just remember that you most likely will have to rebuild the calipers, maybe bushings, ball joints, hoses....ect. The conversion can be completly done for under $350.
Author:  Brian [ Wed Nov 12, 2008 6:35 am ]
Just tell your wife with disc brakes you will actually be able to stop your car :D Safety first :!:
