It is currently Tue Nov 17, 2026 1:30 pm
PostPosted: Sun Nov 09, 2008 8:35 am
I have always wondered who built this: http://www.slantsix.org/articles/turbo- ... l-side.jpg
Duel Dutra's, twin turbo's. Did it ever run?
Chris'
Autobody
Restoration
Service
PostPosted: Sun Nov 09, 2008 9:14 am
Funny I don't recall ever seeing a hand crank orifice on any slant six. How would one start this baby with an A 904 attached...
PostPosted: Sun Nov 09, 2008 10:01 am
maybe with a decompression lever like the old 290 cummins had?
or maybe a wind-up inertial starter like the old radial piston engines had? how cool would that be.
http://www.youtube.com/watch?v=Z2ChXmMiXjY
YEAH!
PostPosted: Sun Nov 09, 2008 10:32 am
This was never built. Doug just mocked this up with parts he had lying around.
PostPosted: Sun Nov 09, 2008 10:45 am
That's kinda what I thought. I couldn't see how a starter would fit.
Chris'
Autobody
Restoration
Service
PostPosted: Mon Nov 10, 2008 11:07 am
Now if you used the low starter, V-8 trans with the adaptor.... :twisted:
truthfully, there is no good reason to run dual turbos, unless you set them up as sequential with a diversion valve.
PostPosted: Mon Nov 10, 2008 1:50 pm
If you have dual carbs :roll:
Chris'
Autobody
Restoration
Service
PostPosted: Mon Nov 10, 2008 2:31 pm
Plumb that into the dual 1 barrel manifold you are working on Doug, that would be a neat mockup
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Mon Nov 10, 2008 4:39 pm
what was the point of turning the propeller by hand? Is it some sort of priming?
What's that fuzzy blue thing being hurled this way?
::stick::
BOOSH!!!
PostPosted: Mon Nov 10, 2008 9:50 pm
In that same article there is a picture above that one, is that manifold from a buick turbo coupe? If so how did that one work out?
PostPosted: Mon Nov 10, 2008 10:12 pm
Site Admin
To move oil to various parts of the engine.
CJ
PostPosted: Mon Nov 10, 2008 10:18 pm
Yeah, like out of the bottom cylinders so they don't hydraulic lock!
PostPosted: Tue Nov 11, 2008 8:35 am
oh. yeah i guess it would be good to have oil everywhere and not just in the bottom cylinders
::stick::
BOOSH!!!
