| 66' valiant https://slantsix.org/forum/viewtopic.php?t=3232 |
| Author: | matt g [ Mon Feb 11, 2002 7:37 pm ] |
| Post subject: | 66' valiant |
66' been sitting for 4 yrs ,cam turns ,new plugs /points ,battery . lights won,t come on ,or crank. Live on the coast ,so the rust might have affected the grounds . Where do I start .How do i test the resistor ? help !!!! matt g gholsonfour@msn.com |
| Author: | Doc. [ Tue Feb 12, 2002 4:58 pm ] |
| Post subject: | Re: 66' valiant start-up |
: 66' been sitting for 4 yrs ,cam turns ,new : plugs /points ,battery . lights won,t come : on ,or crank. Live on the coast ,so the rust : might have affected the grounds . Where do I : start .How do i test the resistor ? Sounds like a bad fuseable link or alturnator gauge. Will the engine crank if you connect the two wire posts comming out of the starter? (bridge them with a screwdriver or piece of metal) Give that a try, if it cranks, hotwire the coil and see if it will start. DD |
| Author: | matt g [ Tue Feb 12, 2002 6:46 pm ] |
: Sounds like a bad fuseable link or alturnator : gauge. : : Will the engine crank if you connect the two : wire posts comming out of the starter? : (bridge them with a screwdriver or piece of : metal) Give that a try, if it cranks, : hotwire the coil and see if it will start. : DD havent tried bridging starter yet ,but shouldnt the lights or turn signals work w/out starting ? gholsonfour@msn.com |
| Author: | Dart270 [ Wed Feb 13, 2002 6:30 am ] |
: havent tried bridging starter yet ,but shouldnt : the lights or turn signals work w/out : starting ? If the alt gauge is bad, or terminals loose or broken, then nothing will work. Lou madsenl@its.caltech.edu |
| Author: | Drew Belobaba [ Fri Feb 22, 2002 9:06 pm ] |
| Post subject: | Re: 66' valiant |
: 66' been sitting for 4 yrs ,cam turns ,new : plugs /points ,battery . lights won,t come : on ,or crank. Live on the coast ,so the rust : might have affected the grounds . Where do I : start .How do i test the resistor ? help : !!!! matt g Try wiggling your bulkhead connector. A common problem in old mopars is corrosion of the connector of the main power wire running through the ammeter. Drew rdb787@mail.usask.ca |
