It is currently Sun Nov 22, 2026 1:16 pm
PostPosted: Tue Feb 19, 2002 6:19 am
Hey Doc! I remember you saying something about
concentricity between the crank and the rear main
seal, and that sometimes its way off. Also, that
sometimes you're better off using a rope seal
because of this.
What is a good way for checking this, so that
you use the best seal (rubber or rope) for your
motor? (note: my motor is still in the car, if
this matters).
Thanks
Mike
mike.j.moser@boeing.com
PostPosted: Tue Feb 19, 2002 8:42 am
This is hard to check with the engine assembled and in the car, I check the main seal receiver groove and cap position as part of engine "blueprinting" before the engine is assembled.
For an "in car" re-seal, I would go with the rubber type seal. They are easer to install and more forgiving for your in car reseal job.
: I remember you saying something about
: concentricity between the crank and the rear
: main
: seal, and that sometimes its way off. Also,
: that
: sometimes you're better off using a rope seal
: because of this.
: What is a good way for checking this, so that
: you use the best seal (rubber or rope) for your
: motor? (note: my motor is still in the car, if
: this matters).
: Thanks
: Mike
