| Surging problems https://slantsix.org/forum/viewtopic.php?t=32364 |
| Author: | 81dodged150 [ Fri Nov 21, 2008 11:05 am ] |
| Post subject: | Surging problems |
On my 81 dodge D150 truck when i have the headlights on they sometimes get bright then go dim and if i have the blower fan on it will increase the speed and then die down. They both do it at the same time. Also when the lights are on i dont have any low beams. I replaced the bulbs awhile ago and when i bought the truck the guy changed the dimmer switch to. I tested the switch and it works according to my voltage meter. I checked the wires and there is no shorts. So i was wondering if any one here knew what the problem is. |
| Author: | Ed Mullen [ Fri Nov 21, 2008 2:20 pm ] |
voltage regulator? |
| Author: | SlantSixDan [ Fri Nov 21, 2008 2:32 pm ] |
Yep, the surging voltage is likely a problem with the voltage regulator and/or alternator. The headlight problem is likely a faulty (open) connection between the high/low beam switch and the wiring harness, or in the low beam feed wire between the high/low beam switch and the headlights. You really need factory wiring diagrams to chase down faults like this; recommend you buy a factory service manual as soon as you can. |
| Author: | 81dodged150 [ Sun Nov 23, 2008 12:05 pm ] |
| Post subject: | reply |
When the lights are on they work fine with the high beams but as soon as you click the dimmer switch they just shut off. So i dont know if that would be an open circut. They worked fine until one day tehleft side just didnt come on one day so i replaced both of them and it never had lows since then. |
| Author: | Reed [ Sun Nov 23, 2008 12:30 pm ] |
Possible a bad ground or corroded terminals. Have you tried cleaning all connectors and grounds? |
| Author: | SlantSixDan [ Sun Nov 23, 2008 2:04 pm ] |
| Post subject: | Re: reply |
Quote: When the lights are on they work fine with the high beams but as soon as you click the dimmer switch they just shut off. So i dont know if that would be an open circut.
Yes, it would be an open circuit somewhere between the dimmer switch and the low beam filaments, as I said. Go check it out.It's not bad grounds; if it were that, the high beams wouldn't work. The low and high beams have a common ground path, but separate feed paths. |
