| forged pistons https://slantsix.org/forum/viewtopic.php?t=32396 |
| Author: | stealth swinger [ Sun Nov 23, 2008 4:28 am ] |
| Post subject: | forged pistons |
| Author: | Charrlie_S [ Sun Nov 23, 2008 5:52 am ] |
| Post subject: | Re: forged pistons |
Quote: Most likely you will need to order from a manufacturer. |
| Author: | slantzilla [ Sun Nov 23, 2008 7:34 am ] |
If you keep the tune-up right you won't need forged pistons at a 100 shot. If you're tune-up is wrong forged pistons will just cost more to replace. |
| Author: | stealth swinger [ Sun Nov 23, 2008 8:45 am ] |
| Author: | carpdar [ Sun Nov 23, 2008 5:07 pm ] |
You could use 2.2 liter turbo pistons from an 86-90 dodge daytona with 198ci connecting rods while your engine is still under the knife... I bet that would be cheaper even though you gotta buy the rods and get them hardened or whatever |
| Author: | 66aCUDA [ Mon Nov 24, 2008 5:30 am ] |
If you are going that route then get the new K1 rods stronger and lighter and really cheaper. Frank |
| Author: | Charrlie_S [ Mon Nov 24, 2008 6:01 am ] |
You guys are getting totally off track, here. SS was just looking for a inexpensive way to upgrade from a cast to a forged piston. His bores are good at .040. |
| Author: | 66aCUDA [ Mon Nov 24, 2008 6:13 am ] |
Feature Creep .......Sorry Frank |
| Author: | Doc [ Mon Nov 24, 2008 9:38 am ] |
Quote: You guys are getting totally off track, here. SS was just looking for a inexpensive way to upgrade from a cast to a forged piston. His bores are good at .040.
We gave him the bad news right off the bat, off the shelf forged pistons are no longer available so you order custom or hunt around for some "old stock" someone has held onto.The good news is the K1 / Wiseco deal but that is a bunch of money and you will have to "dust-out" the cylinders to 3.445 (from 3.440) DD |
