It is currently Mon May 18, 2026 11:47 pm
 Post subject: 8.25 Fill Plug.
PostPosted: Wed Nov 26, 2008 2:41 am
Well on my 8.25 the fill plug is always seeping a bit of fluid.. It has one of those Plastic / rubber type push in plugs - - not the thread in type. I have changes to a different plug and still the same problem.
It's impossible to have too much fluid as I have filled it with the correct amount and I has seeped so much for a while it as to be a few ounces under.
Thoughts to stop the leaking?
Should I try soaking the plug in the parts washer solution? I have done that be accident before and Made rubber stuff expand.
Thanks! Greg
