| Timing gear - to the Doc https://slantsix.org/forum/viewtopic.php?t=3241 |
| Author: | Mike [ Wed Feb 13, 2002 6:26 am ] |
| Post subject: | Timing gear - to the Doc |
So Doc, did I damage anything taping the timing gear on the crank like I did? (ref: post on monday). I didn't know the heating up trick. Thanks Mike mike.j.moser@boeing.com |
| Author: | Doctor Dodge (Doug Dutra) [ Wed Feb 13, 2002 7:52 am ] |
| Post subject: | Re: Timing gear - to the Doc |
: So Doc, did I damage anything taping the timing : gear on the crank like I did? (ref: post on : monday). I didn't know the heating up trick. #3 main bearing, thrust surface, front side. Check the end play in the crank, more then .008 and I would take a look at that surface. Is the oil pan already on? The proper damper installation tool and some heat installs these quick and easy.(If you must "tap" on a damper, always stand the engine assy on end, with the crank flange resting on a solid surface, like a concret floor. Use a piece of hardwood or soft metal to tap on and never hit the outer ring) |
| Author: | Mike [ Wed Feb 13, 2002 9:18 am ] |
Hey Doc, can you pull just the #3 main bearing cap to inspect the bearing, or do you have to loosen all the caps to re-torque?? Thanks Mike Quote:
: : #3 main bearing, thrust surface, front side. : Check the end play in the crank, more then .008 : and I would take a look at that surface. : Is the oil pan already on? : : The proper damper installation tool and some : heat installs these quick and easy.(If you : must "tap" on a damper, always : stand the engine assy on end, with the crank : flange resting on a solid surface, like a : concret floor. Use a piece of hardwood or : soft metal to tap on and never hit the outer : ring) mike.j.moser@boeing.com |
| Author: | Doc. [ Wed Feb 13, 2002 11:46 am ] |
| Post subject: | Re: Checking a Main Bearing |
: Hey Doc, can you pull just the #3 main bearing : cap to inspect the bearing, or do you have to : loosen all the caps to re-torque?? It is OK to just remove, check and retorque a single main cap assembly. Look carefully at the side thrust face, see any displaced (smashed) babbit? Also measure the thickness of each side with a micrometer. DD |
