| 8.25 Fill Plug. https://slantsix.org/forum/viewtopic.php?t=32439 |
| Author: | Greg Ondayko [ Wed Nov 26, 2008 2:41 am ] |
| Post subject: | 8.25 Fill Plug. |
Well on my 8.25 the fill plug is always seeping a bit of fluid.. It has one of those Plastic / rubber type push in plugs - - not the thread in type. I have changes to a different plug and still the same problem. It's impossible to have too much fluid as I have filled it with the correct amount and I has seeped so much for a while it as to be a few ounces under. Thoughts to stop the leaking? Should I try soaking the plug in the parts washer solution? I have done that be accident before and Made rubber stuff expand. Thanks! Greg |
| Author: | Charrlie_S [ Wed Nov 26, 2008 5:32 am ] |
Greg, would it be possible to remove the cover, and either thread the hole to use a regular plug, or weld on a "bung" with threads? |
| Author: | 6shotvanner [ Wed Nov 26, 2008 6:34 am ] |
Does the 8.25 have a vent? I don't know diddly on most rearends just wondering if it's not vent properly and leaking out path of least resistance. |
| Author: | Eric W [ Wed Nov 26, 2008 11:05 am ] |
I think the vent is integrated with the junction block for the brake lines. At least thats how it is on my 8 3/4" rear. |
| Author: | Greg Ondayko [ Wed Nov 26, 2008 1:25 pm ] |
Yes this has a vent - Some have a vent like the 8.75's and some have a separate vent tube.. I should check it for blockage though. Thanks, Greg |
