| Overcharging alternator https://slantsix.org/forum/viewtopic.php?t=3247 |
| Author: | Jonathan [ Thu Feb 14, 2002 4:36 pm ] |
| Post subject: | Overcharging alternator |
I have a 1967 soft top Cuda with a 3 speed slant six, 225. Just replaced alternator and it is overcharging battery with engine running. I am in the middle of my first ever engine tune up. Need to locate the ground straps referenced in a manual that may be loose or bad!? Or any advice on what else it could be or needs checking! Thanks thejps@mindspring.com |
| Author: | Doc. [ Thu Feb 14, 2002 6:11 pm ] |
| Post subject: | Re: Overcharging alternator |
: I have a 1967 soft top Cuda with a 3 speed : slant six, 225. : Just replaced alternator and it is overcharging : battery with engine running. I am in the : middle of my first ever engine tune up. : Need to locate the ground straps referenced in : a manual that may be loose or bad!? Or any : advice on what else it could be or needs : checking! : Thanks Your right, the voltage regulator needs a good ground. The v. regulator could also need replacing, some times they get "polarized" or shorted by the failed alternator and shoud be replaced when a new alternator is installed. DD |
