| there it went https://slantsix.org/forum/viewtopic.php?t=3252 |
| Author: | andrew [ Fri Feb 15, 2002 9:01 am ] |
| Post subject: | there it went |
well the motor spun a bearing today. so the new one is all ready in the machine shop getting preped. .60 over bore, full grove bearings, APR bolts, I do need a windage tray and a cam. any info is helpful. I am going for a stronger then stock setup and switching to the forged crank. andrew wagner |
| Author: | Doc. [ Fri Feb 15, 2002 10:14 am ] |
| Post subject: | Re: Well . . . there it went |
: well the motor spun a bearing today. so the new : one is all ready in the machine shop getting : preped. .60 over bore, full grove bearings, : APR bolts, I do need a windage tray and a : cam. any info is helpful. I am going for a : stronger then stock setup and switching to : the forged crank. : andrew wagner I think you got your "money's worth" out of this engine! How many "under Turbo boost" passes / blasts did you make on this stock engine, hundereds or "just" a few dozen? DD |
| Author: | dschumers [ Fri Feb 15, 2002 3:23 pm ] |
| Post subject: | Windage tray? |
: well the motor spun a bearing today. so the new : one is all ready in the machine shop getting : preped. .60 over bore, full grove bearings, : APR bolts, I do need a windage tray and a : cam. any info is helpful. I am going for a : stronger then stock setup and switching to : the forged crank. : : andrew wagner Mike was going to be making another run of trays this winter. He may have an extra one laying around. 308-324-3576 slantzilla@excite.com |
| Author: | andrew wagner [ Sat Feb 16, 2002 7:39 am ] |
| Post subject: | Re: there it went ( watch the web site) |
too many to count!!!I will be posting pics of the new build up on my site. andrew wagner think you got your "money's worth" Quote:
: out of this engine!
: How many "under Turbo boost" passes / : blasts did you make on this stock engine, : hundereds or "just" a few dozen? : DD |
