It is currently Sun Nov 22, 2026 4:25 pm
 Post subject: 1971 Valve adjustment
PostPosted: Fri Dec 05, 2008 6:23 am
Time to adjust valves again, I find all sorts of different opinions on what the adjustement should be.
I actually forgot what i adjusted them to last time. I think it was .04, .06,
What is the actual correct adjustment?
PostPosted: Fri Dec 05, 2008 6:49 am
Here is the valve adjustment procedure with specs.
