| Slant Six V8 Cross compatibililty -Update inc other engines https://slantsix.org/forum/viewtopic.php?t=32572 |
| Author: | 68barracuda [ Tue Dec 02, 2008 8:24 pm ] |
| Post subject: | Slant Six V8 Cross compatibililty -Update inc other engines |
Hi Guys, I am compiling a list of parts that work on both This is what I have so far - I have heard about Hemi oil pump springs and so - but what else exchanges between the lot LA V8 Crank pulley bolt B/RB damper - just need to re apply timing marks B/RB crank timing sprocket and chain B/RB Lifters B/RB Roller lifters - Crane list them same P/N 66515-16 as V8 Starter - well my slant and 318LA has identical units LA V8 Valve springs 340 in particular Ford 302 W valves LA V8 rotor well mine are the same - Chrysler EI systems same P/N rotor The Australian HEMI6 Dizzy fits with a spacer - according to them CHEV SB V8 3 bolt pulleys fit the slant on the damper |
| Author: | slantasaurus [ Tue Dec 02, 2008 8:36 pm ] |
Valve springs will interchange between LA and Slant. 340 springs are what I'm using with my Purple cam. |
| Author: | SV162 [ Tue Dec 02, 2008 9:53 pm ] |
Not Mopar, but if you want bigger valves, Ford Windsor 302 valves fit the Slant. That's what I'm using. |
| Author: | SlantSixDan [ Tue Dec 02, 2008 9:58 pm ] |
Careful with starters. See here. |
| Author: | 68barracuda [ Wed Dec 03, 2008 12:55 am ] |
Read you Dan - OK was thinking South Africa centric we only have the Chrysler reduction gear unit over here - 10-tooth, 33mm-diameter Oh yes the rotors in the electronic dizzys is listed as the same part number - too k the one from my 318 LA and the one from the slant identical down to the partnumbers |
| Author: | SlantSixDan [ Wed Dec 03, 2008 8:23 am ] |
Careful there, too — Lucas- and Bosch- and Prestolite-made distributors on various-year/various-market slant-6s and V8s. |
| Author: | GTS225 [ Wed Dec 03, 2008 7:05 pm ] |
Wasn't it the 426 Hemi spark plug tubes and seals that fit the slant, or just the tube seals? Roger |
| Author: | sandy in BC [ Wed Dec 03, 2008 8:15 pm ] |
Of course the Supra DOHC head is almost a bolt on..... |
| Author: | DusterIdiot [ Wed Dec 03, 2008 8:24 pm ] |
| Post subject: | We should get specific... |
All LA/B/RB/AMC .904 lifters will fit... now with hydraulic lifters (most LA/Some B/Some AMC)...proper oiling will be a problem... I wouldn't include roller lifters although they fit, the cam blank is a $1K pop before you apply the grind to it... -D.Idiot |
| Author: | SlantSixDan [ Wed Dec 03, 2008 10:22 pm ] |
Hemi V8 spark plug tubes are way longer than slant-6. No chance of interchange. |
| Author: | 68barracuda [ Wed Dec 03, 2008 10:49 pm ] |
Some of the older 4 cylinder toyota sparktubes is an close fit |
| Author: | 68barracuda [ Wed Dec 03, 2008 10:50 pm ] |
Quote: Of course the Supra DOHC head is almost a bolt on.....
wise ..........a |
