It is currently Sun Nov 22, 2026 9:15 pm
PostPosted: Sat Dec 06, 2008 6:29 pm
The Slant 6 in my 72 Swinger has been swapped from the original 198 to a later year 225.
Are there any definitive markings I can look for to tell me EXACTLY what year the engine is in my Swinger?
Where are some identifying numbers located on the block and cylinder head.
What are some numbers I might find and how do they decode?
The reason I know the engine has been swapped,is because the carb is a 1945 series instead of the 1920 Holley,and there "were" emissions items(Ive removed them as we are emmissions exempt) on the engine that could only be found on a later engine.
72 Swinger Special Originally a 3 speed 198/6 car now has a 225 with the 3 speed
72 B200 Shorty Van 225 /6
4 other Fullsize Mopars from 65-73
PostPosted: Sat Dec 06, 2008 6:35 pm
there is a serial number pad that juts out right at the front passenger side corner of the engine, behind the alternator bracket. the serial number is stamped into that pad, on the same surface as the head gasket seats. remove the alt bracket and clean that area, and post the numbers you find stamped there.
 Post subject: Numbers found
PostPosted: Sat Dec 06, 2008 7:43 pm
Took a little bit of time but I finally got all the clutter moved and cleaned the pad with a wire brush. Numbers i found are as follows:
7225R 2 14 E (MALTESE CROSS)
So what I get so far is its a 225 engine,and it has either undersized or oversized(cant remember) main bearings from the factory according to the Maltese cross.
So what do the other numbers mean?
PostPosted: Sat Dec 06, 2008 9:18 pm
225 engine made on Valentine's Day, 1977.
PostPosted: Sun Dec 07, 2008 5:25 am
Maltese Cross Department Per Factory Manual:
Maltese Cross stamped on the engine numbering pad on right side of block, on top boss directly behind coil indicates that engine is equipped with a crankshaft which had one or more connecting rods and/ or main bearing journals finished .001 inch undersized. The position of the undersize journal or journals is stamped on the center counterweight of the crankshaft.
A Maltese Cross with an X indicates that all connecting rods and/ or main bearing journals are .001 inch undersize.
Connecting rod journals will be identified by the letter "R" and main bearing journals by the letter "ME". For example "M1" indicates that No. 1 main bearing is .001 inch undersize.
PostPosted: Sun Dec 07, 2008 10:43 am
what would be the reasoning behind the connecting rods and/ or main bearing journals finished .001 inch undersized?
put your seatbelt on. Ima try sumthin
Proud NEW owner of a rusted project 1967 Plymouth Valiant with a 170 slant six
PostPosted: Sun Dec 07, 2008 11:02 am
Crank wouldn't polish to spec without undersize grind, factory didn't want to waste the crank.
Users browsing this forum: Google [Bot] and 11 guests
