| Black crinkle paint https://slantsix.org/forum/viewtopic.php?t=32628 |
| Author: | NewSlanter [ Thu Dec 04, 2008 6:30 pm ] |
| Post subject: | Black crinkle paint |
Can anyone recommend a good brand of crinkle finish paint? I want to do my valve cover. Also, any tips on application? I've never used the stuff before. Thanks in advance, Nat |
| Author: | SlantSixDan [ Thu Dec 04, 2008 8:41 pm ] |
VHT make a very good black, grey, or red wrinkle finish in spray cans. Application is pretty much like other paints: paint warm but not hot, parts clean-clean-clean and warm but not hot, multiple coats, keep the can moving, etc. |
| Author: | NewSlanter [ Thu Dec 04, 2008 11:05 pm ] |
Thank you sir! |
| Author: | dakight [ Fri Dec 05, 2008 3:39 am ] |
Read the directions on the can and follow them to the T. It's been a while since I've used wrinkle finish paint but as I recall you lay down the first coat and let it dry for a specified time then apply the second coat. The second coat shrinks when it dries to produce the wrinkle finish. |
| Author: | KBB_of_TMC [ Mon Dec 08, 2008 11:10 am ] |
I put down a layer of Krylon black primer and then heavy wet coats (per instructions) of Krylon black wrinkle paint; it worked quite well and has lasted for years on my air cleaner. Generally, I've been very pleased with the durability of Krylon and far less so with some other brands. |
