It is currently Sun Nov 22, 2026 8:38 pm
PostPosted: Mon Jun 11, 2007 4:04 pm
I have two slant sixes both with solid lifters i want to change to hyd. lifters. I was wondering if this can be done these engines one is a 78 and the other is an 80. Any help would be nice.
PostPosted: Mon Jun 11, 2007 4:49 pm
Yes, it can be done but in general, the solid lifter set-up is better in terms of performance and reliability.
PostPosted: Mon Jun 11, 2007 4:50 pm
I will be following this thread as I am curious about the pros and cons of both; mostly because I don't know much about either!
PostPosted: Mon Jun 11, 2007 7:26 pm
Solid lifter advantages:
•Much greater selection of camshafts
•Much less intricate top-end/valvetrain oiling, fewer small passages to get starved for oil on cold startup and/or clogged in the long run.
•Solid lifters cannot fail, they can only get worn out (and that happens only after a lot of miles or in the event of some catastrophic problem inside the engine. Hydraulic lifters can fail
Hydraulic lifter advantage:
•You never have to adjust your tappet clearance. *yawn*
PostPosted: Mon Jun 11, 2007 8:34 pm
If you really want to do a hydraulic cam, I have an Ultradyne that has never been installed. It is a relatively mild one, under .500" lift so I will never use it. PM me if you are interested, I will be going down to my shop Wednesday. :shock:
PostPosted: Tue Jun 12, 2007 8:24 am
The non-adjustable rocker arms used wuth the Hyd. system is the show stopper for me.
Anytime you have non-adjustable rocker arms, you have to spend a lot of extra time and attention during cylinder head set-up in order to ensure that you get all the valve stem lengths the same. (even lifter pre-load)
When you get some wear in the valve train, you are stuck with no easy way to adjust the extra clearance out. (outside of pulling the head doing a valve job)
PostPosted: Thu Jun 14, 2007 4:48 pm
Backing up to the orginal question: The solid lifter cam would have to be swapped out with a hydraulic lifter cam, then the hydraulic lifters installed, along with hydraulic lifter rocker arms and rocker arm shaft.
As for DD's last post, if you tell you machine shop that you MUST have the top of all the valves level level after a valve grind, AND they can do that, then you should be good to go. I have an $800 oversize-valve-head because of bad machine work during the process of getting it right.
Troy
PostPosted: Thu Jun 14, 2007 5:11 pm
Yes, a hydraulic cam requires the whole hydraulic valve train. Rockers, shaft, pushrods, and lifters. I would also definitely run a high volume oil pump. This motor oils the lifters from the top down. There also used to be a full grooved rear cam bearing too, but the hydraulic cam that I have has the rear journal fully grooved instead.
 Post subject: Snicker...
PostPosted: Thu Jun 14, 2007 5:15 pm
Aw crap, I gotta go give my machinist in Woodburn a whole load of crap since one valve stem was under by .001.... (no wonder I have to lash a little tighter on cylinder number 3...) :roll:
 Post subject: Re: Snicker...
PostPosted: Thu Jun 14, 2007 5:34 pm
...Aw crap, I gotta go give my machinist in Woodburn a whole load of crap since one valve stem was under by .001.... (no wonder I have to lash a little tighter on cylinder number 3...) :roll:
Even valve stem heights are only important with the Hyd. set-up, solid lifter engines with adjustable rocker arms don't care.
PostPosted: Thu Jun 14, 2007 8:41 pm
Are you saying that every slant from 1981 to 1987 should have a high volume oil pump put in?
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Thu Jun 14, 2007 8:43 pm
IIRC, the hydro motors got a thick rotor pump to start with.
If it is fine now I wouldn't bother. If I were changing a pump anyway I would do the high volume thing. :D
PostPosted: Sat Dec 06, 2008 9:06 pm
Is this a worth while investment in any HP build?
PostPosted: Sat Dec 06, 2008 9:15 pm
No. High-volume pumps can cause more problems than they solve. Search the board for details, but in a nutshell, a carefully-built regular pump generally provides all the volume needed, and a high-volume pump puts much more drag on the relatively fragile cam worm to oil pump drive pinion junction, which can frag the pinion.
PostPosted: Sun Dec 07, 2008 6:37 am
That was what I was thinking. I put a HV on my 360 and later found out it wasn't necessary.
