It is currently Mon May 18, 2026 8:20 pm
 Post subject: Flywheel bolt size
PostPosted: Mon Dec 15, 2008 9:22 am
I've read they are 7/16 - 20. is that right?
Also, why is there a HUGE discrepancy in cost? some go for a buck a piece and some are as much as $40 for a set? will grade 8 or 10 bolts from the depot work or do I have to order and wait for them to show up?
PostPosted: Mon Dec 15, 2008 11:16 am
Yeah, that's right. You want shouldered flywheel bolts not fully threaded hardware store stuff. Small block Chevy's use the same bolt so they are easy to find. Try Pioneer 859026.
