| Doc, rear main concentricity https://slantsix.org/forum/viewtopic.php?t=3275 |
| Author: | Mike [ Tue Feb 19, 2002 6:19 am ] |
| Post subject: | Doc, rear main concentricity |
Hey Doc! I remember you saying something about concentricity between the crank and the rear main seal, and that sometimes its way off. Also, that sometimes you're better off using a rope seal because of this. What is a good way for checking this, so that you use the best seal (rubber or rope) for your motor? (note: my motor is still in the car, if this matters). Thanks Mike mike.j.moser@boeing.com |
| Author: | Doc, on the road [ Tue Feb 19, 2002 8:42 am ] |
| Post subject: | Re: Rear main seal receiver groove concentricity |
This is hard to check with the engine assembled and in the car, I check the main seal receiver groove and cap position as part of engine "blueprinting" before the engine is assembled. For an "in car" re-seal, I would go with the rubber type seal. They are easer to install and more forgiving for your in car reseal job. DD Quote:
: I remember you saying something about : concentricity between the crank and the rear : main : seal, and that sometimes its way off. Also, : that : sometimes you're better off using a rope seal : because of this. : : What is a good way for checking this, so that : you use the best seal (rubber or rope) for your : motor? (note: my motor is still in the car, if : this matters). : : Thanks : Mike |
