| a 904 kickdown servo. Parts missing? https://slantsix.org/forum/viewtopic.php?t=32764 |
| Author: | Roelof [ Sat Dec 13, 2008 5:56 am ] |
| Post subject: | a 904 kickdown servo. Parts missing? |
I am rebuilding my a904 tranny and have encountered a problem. The pictures in the manual show a kickdown servo assembly with two springs, a small one and a large one. The servo in my tranny only has one. The small one, and a piston seems to be missing. Did I misplace a part? Or are there different servo's for different years? Roelof |
| Author: | Joshie225 [ Sat Dec 13, 2008 11:06 am ] |
It sounds like your servo is fine and that the picture is for a servo from a 727. My book shows a second, relatively small spring and a washer with the note A-727 only. From outside (bottom) to the inside you should have a snap ring, piston rod guide with it's sealing ring, a snap ring, piston rod and the servo piston with 2 sealing rings. |
| Author: | Roelof [ Sat Dec 13, 2008 1:13 pm ] |
...it does sound like something is missing. This is all there is: ![]() ![]() So is the piston missing? The ATSG-guide I used for the rebuild is for the 727 and 904, so I figured some parts might not be exactly the same. That's why a photographed almost everything. And a forgot to take a picture of the servo when I took it out |
| Author: | Joshie225 [ Sat Dec 13, 2008 1:57 pm ] |
It does appear the piston is missing. Are you sure it came out of the case? |
| Author: | Roelof [ Sat Dec 13, 2008 2:30 pm ] |
...ehmm. I knew I overlooked something. Now I know what these spare rings were for Thanks |
| Author: | Joshie225 [ Sat Dec 13, 2008 3:19 pm ] |
So the piston was still in the case? That's good because you wouldn't have 2nd gear without it. |
| Author: | Roelof [ Sat Dec 13, 2008 3:31 pm ] |
I spent some time looking for a piston. The case was the only place i didn't look |
