SBP Steelies, 4.5 or 5.5?
https://slantsix.org/forum/viewtopic.php?t=32768
Page 1 of 1
Author:  kcoyle [ Sat Dec 13, 2008 7:56 am ]
Post subject:  SBP Steelies, 4.5 or 5.5?
I need to upgrade the 13inch rims on my 65 barracuda to 14's. From what I've read a 205 is the widest one should go on a 5.5 rim, and 185 on a 4.5.
Is there any real benefit of trying to find 5.5 steelies (which seem to be hard to find) to run a 205, or can I possibly run a 195 on the 4.5 and call it a day? I'm assuming either option would be better than what I have, which is 4 mismatched tires in 185/80/13.
Kevin
Author:  emsvitil [ Sat Dec 13, 2008 2:34 pm ]
A 4.5 is too narrow for a 195, you really wouldn't gain anything except a lighter pocket in comparison to a 185........
Author:  SlantSixDan [ Sat Dec 13, 2008 3:17 pm ]
That's right. If you're in a time/budget crunch and can only find 4½" rims, use appropriate tires (I have BF Goodrich Traction T/A in P185/65R14s or something close to that size on 4½" rims on my '71). If you can afford to wait (or buy new), get 5½" rims.
195s are too wide for effective use on the narrower rims.
Author:  kcoyle [ Sat Dec 13, 2008 5:45 pm ]
Understood. I'm hoping then to get the 5.5 rims, as there are little tire choces for the 4.5 rims in a 185. (at least according to tire rack)
I have available to me locally 4.5 steelies and SBP rallys (i guess 5.5?) Are the 5.5 steelies really that hard to find?
Author:  SlantSixDan [ Sat Dec 13, 2008 6:11 pm ]
In most of North America, finding any small-bolt wheels is getting to be a real trick. :-(
I might be wrong about the tire size on my '71. I'll look tomorrow. I do like the Traction T/A tires, whatever size they are.
Author:  kcoyle [ Sun Dec 14, 2008 10:19 am ]
Would a 1974 /6 dart be a suitable donor car to forget the whole SBP thing and go to a BBP?
It seems I can get a whole car with disk brakes, wheels, rear, etc easier and cheaper than parts.
thanks!
Author:  Rug_Trucker [ Wed Dec 17, 2008 5:43 am ]
My Duster came with 6.5 X 14 SBP chrome reverse wheels. Guess I will save them.
Author:  kcoyle [ Fri Dec 19, 2008 8:10 am ]
well, it looks like I'm going with 14 x 5.5 rallys on the barracuda. What would be the best tire size, 205/70/14's or 195/70/14's?
Or can I run the same tires but in 60 series for less sidewall and slightly better gearing? Or is that just a real bad idea? Lord knows I'm full of them.
Author:  emsvitil [ Fri Dec 19, 2008 4:21 pm ]
Either one works. I went with the 195/70s because they were 20% cheaper and only 5mm smaller (tire manufacturer data)
You can use a slight tire size diameter change to correct for speedometer/odometer error. (205/70 largest diameter 205/60 smallest). You just need to know how accurate it is now with whatever size tire you currently have, then you can do some math to figure what size to get.
Author:  kcoyle [ Sat Dec 20, 2008 7:38 am ]
Thanks. 20% cheaper is the math that makes the most sense to me right now. I think I'll try a 205/60/14, that should give me about an inch less sidewall than the stock 13's.
It looks like a traction t/a in that size is 59 bucks at tirerack.
