| Roller camshafts https://slantsix.org/forum/viewtopic.php?t=3277 |
| Author: | Brian Parsons [ Tue Feb 19, 2002 3:07 pm ] |
| Post subject: | Roller camshafts |
In your artical about stroking the slantsix in the stroker 170 section, there was a comment about a roller cam. I am very interested in finding out were to get such a thing along with the related valve train. I have a 360 in a duster that has one. What a difference. I can't see why anyone would put in a flat tappet cam if you had the choice of a roller. Any information on the subject will be used in my next slanter project. Thanks bparsons bparsons@coi-world.com |
| Author: | Tim Keith [ Tue Feb 19, 2002 11:14 pm ] |
| Post subject: | Re: Roller camshafts |
I think you have to make the entire cam shaft using a custom steel core. I think cast iron is too soft. I don't think these are commercially available! I think you will have to find a machinist to make this part. I saw an article in Hot Rod magazine which stated some advantages of using roller bearings to replace the babbet. If you're going to spend money in a motor there's plenty of ways to do it! Quote:
: : In your artical about stroking the slantsix in : the stroker 170 section, there was a comment : about a roller cam. I am very interested in : finding out were to get such a thing along : with the related valve train. I have a 360 : in a duster that has one. What a difference. : I can't see why anyone would put in a flat : tappet cam if you had the choice of a : roller. Any information on the subject will : be used in my next slanter project. : Thanks bparsons tkeith@mindspring.com |
| Author: | Doc . . . in LA [ Thu Feb 21, 2002 1:56 pm ] |
: In your artical about stroking the slantsix in : the stroker 170 section, there was a comment : about a roller cam. I am very interested in : finding out were to get such a thing along : with the related valve train. I have a 360 : in a duster that has one. What a difference. : I can't see why anyone would put in a flat : tappet cam if you had the choice of a : roller. Any information on the subject will : be used in my next slanter project. : Thanks bparsons I have my roller cam core (cast steel) project moving again. I will post some additional info. when I get back to my home computer. (next week) I am like you, once you run a roller, there is no going back to flat tappet cams. DD |
| Author: | Brian Parsons [ Fri Mar 08, 2002 6:05 am ] |
Are you slill working on the project or is it on hold again? bparsons@coi-world.com |
