| # 4 rod bearing https://slantsix.org/forum/viewtopic.php?t=3278 |
| Author: | andrew wagner [ Tue Feb 19, 2002 5:59 pm ] |
| Post subject: | # 4 rod bearing |
Hey guys I just found the spun bearing in the # 4 rod. I am going to just replace it and put the motor back in. The crank is fine I had the michinist take a look and he oked it. I am still building a new motor and a head for the dart but I will take my time doing it. andrew wagner |
| Author: | Charlie Schmid [ Wed Feb 20, 2002 8:57 pm ] |
| Post subject: | Re: # 4 rod bearing |
: Hey guys I just found the spun bearing in the # : 4 rod. I am going to just replace it and put : the motor back in. The crank is fine I had : the michinist take a look and he oked it. I : am still building a new motor and a head for : the dart but I will take my time doing it. : : andrew wagner Andrew, While you are in there, I would suggest installing full groove main bearings. It will help the rod bearings to live. Charlie flturbo6@aol.com |
| Author: | Doc . . . in LA [ Thu Feb 21, 2002 1:52 pm ] |
: Hey guys I just found the spun bearing in the # : 4 rod. I am going to just replace it and put : the motor back in. The crank is fine I had : the michinist take a look and he oked it. I : am still building a new motor and a head for : the dart but I will take my time doing it. : andrew wagner Make sure to measure the connecting rod, replace it if the big-end of the rod is out of round or beat-up. Rods get knocked out of round pretty easily so check them closely. DD |
| Author: | andrew [ Thu Feb 21, 2002 4:52 pm ] |
| Post subject: | tug a war |
I got into a tug a war with my self and I think I should just wait for the new built engine. I go back and forth with this think I just have to be patient and do it right. THis way I will have a back up if I need it. My car just got degreased today and will be painted over the weekend. I also ordered a costom grind cam and valve springs from comp cams I will post the spec. soon. thanks guys!!! andrew wagner Quote:
: Andrew, : While you are in there, I would suggest : installing full groove main bearings. It : will help the rod bearings to live. : : Charlie |
