It is currently Tue Nov 24, 2026 2:01 am
 Post subject: 351vgt turbo
PostPosted: Sat Dec 13, 2008 6:23 am
I am working on a easy to adjust machanical control for the variable geometry turbo that is on the new 6.7L cummins. this will give a 1,000-1,500 rpm lower spool than a hx35 but will flow like a hx40(650 hp) I am also building header and manifolds. If anyone would be interested in the vgt than let me know, when I get it done Ill pass the information along or possibly build them for you
Nick
86 d150 turbo /6.
PostPosted: Sat Dec 13, 2008 6:55 am
Is it vacuum controlled originally? I´ve had a couple smaller vnt:s at my Vw diesels, very nice 8)
PostPosted: Sat Dec 13, 2008 7:26 am
originaly they are electronic,It has a speed sensor,acctuator motor, cpu,and it is controled by the ecm via serial bus wires
Nick
86 d150 turbo /6.
PostPosted: Sat Dec 13, 2008 12:01 pm
So how are you going to do it? There are several different kind of controls made in smaller diesel world. I had just 1 boost actuator (not very good, but simple) others 1 boost, and vacuum actuator etc... My GT2052V had vacuum, and GT2359V electric control originally.
PostPosted: Sat Dec 13, 2008 12:52 pm
well I plan on using a light spring(5psi) waste gate accuator with a machanical /ajustable boost controler for the vgt control. and an external waste gate for boost control.I'm shure that the vanes can't open far enough for boost control once its spooled. I may hook up the shaft speed sensor to my laptop for tuneing help. and hopfuly eventualy control it with my megasquirt.
Nick
Nick
86 d150 turbo /6.
PostPosted: Sun Dec 14, 2008 3:32 am
Nick,
Sounds pretty sweet. Didn't know you were Megasquirted too. My two Darts are MSI v2.2.
Keep up the great work!
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 8 guests
