| boosting fuel pump https://slantsix.org/forum/viewtopic.php?t=3287 |
| Author: | Dan [ Fri Feb 22, 2002 10:53 am ] |
| Post subject: | boosting fuel pump |
anyone have info or pics on where on the fuel pump to drill and tap for line to boost using presure from the preserizes side of a turbo? I got a new replacement pump today and would like to modify it rather than the original one on the car. Dan reptylkrib@aol.com |
| Author: | andrew [ Fri Feb 22, 2002 2:56 pm ] |
| Post subject: | Re: boosting fuel pump |
the 2nd page of my web site has pic and a description of the one I did. andrew wagner Quote:
: : anyone have info or pics on where on the fuel : pump to drill and tap for line to boost : using presure from the preserizes side of a : turbo? I got a new replacement pump today : and would like to modify it rather than the : original one on the car. : Dan http://home.earthlink.net/~mrdartgt/ |
| Author: | Doctor Dodge (Doug Dutra) [ Tue Feb 26, 2002 8:02 am ] |
| Post subject: | Re: Pressure fitting fuel pump *PIC* |
: anyone have info or pics on where on the fuel : pump to drill and tap for line to boost : using presure from the preserizes side of a : turbo? I got a new replacement pump today : and would like to modify it rather than the : original one on the car. Here is a PIC of a high volume pump with a 1/16 NPT fitting installed so a plastic tube & ferrel can be installed. (the same stuff used on mechanical oil pressure and vacuum guages) If your pump does not have a lot of extra metal around the vent hole, you can also use a hose "bib" fitting like the ones pressed into carbs to accept the small vacuum advance hose. shoot for a tight press fit and use a little epoxy, the hose must be strong enough to hold the boost and be clamped so it won't pop-off under pressure. DD
