It is currently Wed Nov 25, 2026 12:21 pm
PostPosted: Fri Dec 19, 2008 6:45 pm
Will the stock long rods hold up with a 12.5:1 compression ratio? I am building a Drag Motor and we are calculating a 12.5:1 compression ratio. I am planning on turning the motor about 5,600 RPM.
There is a lot of knowledge on this board, please help.
PostPosted: Fri Dec 19, 2008 7:27 pm
They should hold up until you get over 6500 rpm. After that the small ends tend to separate at times. :shock:
PostPosted: Sat Dec 20, 2008 7:34 am
Thank you Sir...
PostPosted: Sat Dec 20, 2008 8:48 am
A well selected and reconditioned set of 198 con rods will hold-up to 12 - 1 compression, I have used them in 300 HP Slants with-out a problem.
PostPosted: Sat Dec 20, 2008 10:49 am
I also have a set in my junk. They have held up well to as much as 180 hp worth of hose and 6500 rpm. :D
Can't say the same for my KB pistons. :shock: :lol: :lol: :lol: :lol:
Users browsing this forum: DuckDuckGo [Bot] and 4 guests
