| My Chrismas present(s) to myself https://slantsix.org/forum/viewtopic.php?t=32889 |
Page 1 of 5 |
| Author: | 68barracuda [ Thu Dec 18, 2008 10:07 pm ] |
| Post subject: | My Chrismas present(s) to myself |
Hughes roller timing set 12 Hughes valve lifters engnbldr Valves with guides engnbldr 340 valve springs 12 Push rods 1 Harmonic balancer I have also received my 2 Weber carbs And now the main thing - the cam..... Have a choice of ISKY 264/264 228@0.050 .448 46 deg overlap LSA 109, or ISKY 256/256 210@50 .425 32 deg overlap LSA 112deg They are both here but can only afford one |
| Author: | Joshie225 [ Thu Dec 18, 2008 10:20 pm ] |
The Isky 264 for sure. The shorter duration, wider lobe center 256 cam would idle well, but would give up a lot of torque. Did you get valve spring retainers? I like the Comp Cams retainers better than the ones Engnbldr sells. There are no tool marks on the Comp retainers. |
| Author: | 68barracuda [ Fri Dec 19, 2008 2:45 am ] |
Which was my next question - what retainers to use 340 ones? And with all this in mind - what cr to run |
| Author: | wvenable [ Fri Dec 19, 2008 5:59 am ] |
Wow lookin' good under that tree! Under mine I have an Offy valve cover and engine builder valves. Cam selection has been a mystery to me as well. Thanks Lou for trying to help. When I built a 318 and a 440 I used a Hemi grind ( same specs as a stock 426) cam and that worked very well. I am glad I am on a budget. |
| Author: | 68barracuda [ Fri Dec 19, 2008 6:13 am ] |
I agree - budget and plan - this was a long time comming |
| Author: | armyofchuckness [ Fri Dec 19, 2008 7:14 am ] |
That looks a lot like what's under my Christmas tree! I've got an Offy cover, EngineBuilder Valves, 340 springs. I'm going to need to get some retainers too. I guess I'll be checking out CompCams for theirs unless there's good reason to look elsewhere. |
| Author: | CARS [ Fri Dec 19, 2008 7:57 am ] |
Fanie, which intake are you going to run? |
| Author: | 68barracuda [ Fri Dec 19, 2008 8:10 am ] |
The Original Longram Dually - so I can take installation pics - and fettle the throttle linkages for you guys and of course........ |
| Author: | vynn3 [ Fri Dec 19, 2008 10:48 am ] |
My Xmas present to myself? A new iPhone. How is this slant six related? I can come to this forum any time, anywhere! You guys don't want to know where I am right now... |
| Author: | SlantSixDan [ Fri Dec 19, 2008 11:02 am ] |
Quote: How is this slant six related?
Easy: SLANTA CLAUS!![]() Ho-ho-ho! (had my first-ever request to play Santa at a Xmas party this year...) |
| Author: | wvenable [ Fri Dec 19, 2008 11:28 am ] |
Good for you oh bearded one! Are you going to go prematurely white? |
| Author: | SlantSixDan [ Fri Dec 19, 2008 11:42 am ] |
Prematurely? Donno. There's about...15 or 20 percent white in it, even when it's fully thawed. It doesn't bother me; bring it on, ho-ho-ho! |
| Author: | GENT [ Fri Dec 19, 2008 11:46 am ] |
Dear Slanta Claus- I want an aussie speed intake manifold and gasket set. A shiney new carb. And a set of dutra duals for Christmas. Oh and world peace....But you could skip that last one as long as I get the Dutra Duals |
| Author: | Joshie225 [ Fri Dec 19, 2008 11:51 am ] |
Quote: Which was my next question - what retainers to use 340 ones?
Yes, 340 style retainers are what you need. Comp Cams part number 744-12 or if you want extras -16. And with all this in mind - what cr to run 9.5:1 would be fine with the Isky cam. |
| Author: | armyofchuckness [ Fri Dec 19, 2008 11:53 am ] |
Quote: Good for you oh bearded one! Are you going to go prematurely white?
I think some of us on the forum are driving him there already. |
| Page 1 of 5 | All times are UTC-07:00 |
