| serial number https://slantsix.org/forum/viewtopic.php?t=32895 |
| Author: | Joe Colby [ Fri Dec 19, 2008 5:36 pm ] |
| Post subject: | serial number |
Can someone break this serial number down for me on my 62?? Thanks Engine S/N S22 6 08 2 I also have the numbers from the drivers side fender. The plate is screwed on which makes me nervous. the car is light blue body and white top. SO#0709 5081 BDY#133 TRM#521 PNT#DW4 I would really like the paint code broken down so I could take it to a shop and get a quart of the original color if possible. It's had one repaint and a knowledge friend said it had too much metallic to be original. Thanks. Joe |
| Author: | SlantSixDan [ Fri Dec 19, 2008 6:11 pm ] |
| Post subject: | Re: serial number |
Quote: Engine S/N S22 6 08 2
Means it's a 1962-model iron 225 engine built on June 8, 1962, second shift.Quote: SO#0709 5081
Can't decode anything but the paint codes for you out of this, 'cause my '62 info is over at the office, and driving conditions are awful right now. BDY#133 TRM#521 PNT#DW4 Your paint job is originally Luminous Blue Poly (PPG #12416) and Ermine White (PPG #8293). |
| Author: | Joe Colby [ Sat Dec 20, 2008 4:23 am ] |
Dan, Thank you very much. I hope you didn't get hit with all that ice that hit southern Maine and almost closed down NH. Spring is almost right around the corner. OK, maybe a little further than that but it is on it's way. Mud season will be here before you know it. Thanks again. Joe |
