| were most valiants c clip or non rear ends mine is 71? https://slantsix.org/forum/viewtopic.php?t=32901 |
| Author: | Mr Scamp [ Sat Dec 20, 2008 6:52 am ] |
| Post subject: | were most valiants c clip or non rear ends mine is 71? |
I want to sure grip mine , is the only way to know what's in it, to open it up? |
| Author: | slantvaliant [ Sat Dec 20, 2008 2:34 pm ] |
7.25" and 8.75" rear ends use bearing retainers at the ends of the axle housings, not C-Clips. The 8.25" rear uses C-clips. |
| Author: | Mr Scamp [ Sat Dec 20, 2008 4:04 pm ] |
| Post subject: | Is there any difference, other than cone and clutch types of |
7.25 rear end suregrips or are they all interchangeabled? I've been told they are not. thanks, Mark |
| Author: | THOR [ Sat Dec 20, 2008 5:50 pm ] |
| Post subject: | Re: Is there any difference, other than cone and clutch type |
Quote: 7.25 rear end suregrips or are they all interchangeabled? I've been told they are not. thanks, Mark
Not quite sure what the question is... but the 7.25" is typically not a SG unit. I have installed the SG case into my 7.25" with no issues at all. It works beautifully.~THOR~ |
| Author: | Mr Scamp [ Sun Dec 21, 2008 8:16 pm ] |
Just curious, I have grabbed 2 very nice sg units 7.25 and am looking at using either 3:55 gear or 3:90, do you have an opinion. Does the 3:90 rap out too quickly? I've heard the 3:55 still is pretty good for highway. |
| Author: | THOR [ Mon Dec 22, 2008 1:48 am ] |
3.23:1 is what I have found to be "best" for combination (city/hwy) driving. 3.55:1 will get the engine spinning pretty good at 60 mph (2500-2600 RPM depending on tire size), anything above 60, and your miles-per-gallon starts dropping fairly fast. 3.90:1 is 55mph max freeway. Otherwise you will experience that large drop in mileage, due to high RPM. At 60 mph (depending on tire size) you will be turning a little less than 3k RPM. If you could get an OD with the 3.90:1 you can probably get away with 60 mph without doing too badly on mileage. Ultimately, from what I have found, 3.23:1 with an overdrive is one of the best combos you can get. Gets you decent pep at low RPM (city) driving, but it wont kill on the freeway because of the overdrive. Decide what your main uses for this car are going to be, and build it from there. My .02 ~THOR~ |
