It is currently Mon Jun 22, 2026 10:41 am
PostPosted: Sat Dec 27, 2008 6:27 am
I have a 64 barracuda that I am working on. The car has had a lot of changes over the years and many parts have been changed out and replaced with diffrent years. I'm now trying to peice back the suspension and have found the rear end is a 8 1/4" out of a 73 to 76 I think? It has 10 bolts on the cover. When I took the rear end and spring out of the the car I noticed the bolt going through the largest bushing was to small for the bushing, but it fit well in the spring bracket that bolts to the car.
I don't know if I should drill out the bracket and get a larger diameter bolt or if I can find a bushing that is the same outside diameter and has a smaller inside diameter? Did they change the diameter of the bolts betwwen 64 and 73? I am assuming the springs were also from the donnor car.5
Also, When I took apart the leaf springs there where some thin peice of metal that looked and felt like lead. The thin plates fell appart when removed? Can I get away without these pieces when I reasemble the leafsprings?
thanks Joe
1964 barracuda 198 slant
