Painting air cleaner
https://slantsix.org/forum/viewtopic.php?t=32924
Page 1 of 1
Author:  00spy [ Sun Dec 21, 2008 3:36 pm ]
Post subject:  Painting air cleaner
The lid on my air cleaner has some bad rust on it . I tried to get it all off , but did not do a good job . It just keeps popping up. What is the best way to grind the rust off, and what is the best paint to use on it ?
Thanks
Dave
Author:  steponmebbbboom [ Sun Dec 21, 2008 4:37 pm ]
what is your budget?
have it sandblasted at an engine rebuilder's and paint it with black rustoleum if you are on the cheap and have no equipment like grinders to work with.
want the best? have it hot-tanked and powder coated.
if you have a grinder, use it. buying it will put you over the cost of these suggestions but you will have a tool you can use on other projects to recoup your losses.
Author:  00spy [ Sun Dec 21, 2008 4:57 pm ]
Thanks for your reply steponme, It is really pitted , I probably wont do anything right now , but I'll check into your suggestions, I might check and see if I can find one in a junkyard .
Dave
Author:  Aggressive Ted [ Tue Dec 23, 2008 6:52 pm ]
00spy,
Hand sand or sand blast if needed.
The best possible product to use is POR-15. Order the starter kit and flow the process. It will stop the rust from returning and make it look very nice. It flows well when using a brush and dries like glass.
I have used it on my battery tray, frame, rear end, wheels, springs, trunk, radiator, around the window frames, etc.. great stuff! On the frame and radiator I used the Chassis Coat gloss black paint.
Author:  00spy [ Wed Dec 24, 2008 1:19 pm ]
Thanks Ted ,
I didn't think about that ,sounds like a good deal .
Dave
