Rear Main Seals
https://slantsix.org/forum/viewtopic.php?t=32940
Author:  Slanted Down Under [ Tue Dec 23, 2008 2:49 am ]
Post subject:  Rear Main Seals
Hi, I'm a newbie so hope someone can help, my question is there any differences in blocks with the two styles of rear main seals?
Cheers
p.s. How do you attach pics to your profile?[/img]
Author:  Eric W [ Tue Dec 23, 2008 11:18 am ]
The rubber seals (or neoprine or whatever they are) replace the factory rope seals. There is an artical on how to replace the seal and oil pan gasket in the articals section of this site (on home page). Good luck getting the upper (engine side) seal out if you don't have the crank out (took me two days on my back last time I did a rear main seal with the engine in the car)! A tool called a "Sneaky Pete" will help.
Author:  Slanted Down Under [ Tue Dec 23, 2008 2:23 pm ]
Thanks Eric,
I'm about to pull my motor for to do a auto to manual conversion so decided I'ld fix that leak at the same time.
Cheers
