| Conversion U-joint https://slantsix.org/forum/viewtopic.php?t=3297 |
| Author: | Rick Covalt [ Mon Feb 25, 2002 2:12 pm ] |
| Post subject: | Conversion U-joint |
Does anyone have a part # for the conversion U-joint, for the small joint to large joint.Is it available at the local auto parts stores or is it a special item that has to be purchase elsewhere. Thanks for any help. Rick rcovalt@innernet.net |
| Author: | DusterIdiot [ Mon Feb 25, 2002 4:56 pm ] |
| Post subject: | Re: Conversion U-joint |
: Does anyone have a part # for the conversion : U-joint, for the small joint to large : joint.Is it available at the local auto : parts stores or is it a special item that : has to be purchase elsewhere. Should be available from your local parts store, they need a u-joint to join a 7260 (small) to a 7290 (large) yoke. If you have a good parts store or some one who knows mopars they will know exactly what u-joint you need.. good hunting, -D.Idiot |
| Author: | Loghead [ Tue Feb 26, 2002 4:33 pm ] |
: Should be available from your local parts : store, they need a u-joint to join a 7260 : (small) to a 7290 (large) yoke. If you have : a good parts store or some one who knows : mopars they will know exactly what u-joint : you need.. : : good hunting, : : -D.Idiot If the auto parts store doesn't have one, try a driveshaft shop. thelogs@cox.net |
| Author: | Will [ Tue Feb 26, 2002 4:40 pm ] |
napa has them I will try to find the number. I have it written down somewhere. Will Quote:
: Does anyone have a part # for the conversion : U-joint, for the small joint to large : joint.Is it available at the local auto : parts stores or is it a special item that : has to be purchase elsewhere. Thanks for any : help. : : Rick slantsix@netzero.net |
| Author: | Marc Medina [ Wed Feb 27, 2002 5:00 am ] |
: If the auto parts store doesn't have one, try a : driveshaft shop. Lakewood used to list it in thier catalog, so Summit and Jegs should have it. Precision is another brand to check. marc_medina@hotmail.com |
