It is currently Mon Nov 23, 2026 12:32 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
PostPosted: Sat Feb 23, 2002 10:43 pm
Howdy,
1966 Dodge Dart GT. Length of ownership: 1 week. I have no idea where the hazard light switch is. Since my car tends to stall when the engine is cold, this info would help out immensely. Tom.
kimpelt@pdx.edu
PostPosted: Sun Feb 24, 2002 5:47 am
: Howdy,
: 1966 Dodge Dart GT. Length of ownership: 1
: week. I have no idea where the hazard light
: switch is. Since my car tends to stall when
: the engine is cold, this info would help out
: immensely. Tom.
I purchased my 1966 new and it was mounted under the dash on the left next to the emergency brake light, almost directly above the emergency brake handle. It is a toggle switch.
Ron
slantsixdart@aol.com
PostPosted: Sun Feb 24, 2002 9:58 am
: Howdy,
: immensely. Tom.
You may need to recheck the choke adjustment, basically try to figure-out why the car is stalling-out when cold.
Take a look at the choke adjustment article for some ideas:
<A HREF="http://www.slantsix.org/articles/choke-adjust/choke-adjust.htm">http://www.slantsix.org/articles/choke-adjust/choke-adjust.htm</A>
PostPosted: Mon Feb 25, 2002 8:11 am
Hi. Thanks for the speedy replies. I looked for the switch again and am certain that I do not have any hazard lights. I'll just focus on fixing my idle problem first and worry about installing a switch at a later date. I have run into the nicest Dart owners around town this past week. Seems like a nice little community. Thanks again. Tom.
: Howdy,
: immensely. Tom.
kimpelt@pdx.edu
PostPosted: Mon Feb 25, 2002 12:39 pm
: I purchased my 1966 new and it was mounted
: under the dash on the left next to the
: emergency brake light, almost directly above
: the emergency brake handle. It is a toggle
: switch.
This must have been an option. The '66 Dart that I had, did not have any hazard lights.
klesteb@aol.com
