Weird Occurrence
https://slantsix.org/forum/viewtopic.php?t=32990
Page 1 of 1
Author:  jmccabe [ Fri Dec 26, 2008 10:34 am ]
Post subject:  Weird Occurrence
i was driving down the road yesterday and my car made this loud backfire [right now i have no muffler and it was freezing outside] and my car jerked forward and shut off so i pulled onto a off ramp and checked my oil and for holes in the block and any leaking and couldn't find anything out of the ordinary. so i started it back up it started just fine and i drove about 10 feet and the car jerked forward again and then smoke started coming up from the hood [not the front of the hood the sides] and a cop pushed me to a parking lot and i tried starting it again and it made no sound at all when i turned the key not even the starter.
Author:  Eric W [ Fri Dec 26, 2008 11:03 am ]
Sounds electrical. Could you be more specific as to where the smoke came from (fire wall, wires along engine, near battery)? What year is your car?
Author:  jmccabe [ Fri Dec 26, 2008 4:31 pm ]
I've got a 1970 Plymouth valiant and the smoke looked to be coming from the fire wall and the smoke smelled rubbery
Author:  jmccabe [ Fri Dec 26, 2008 10:14 pm ]
i think it might be my fusible wire its split and that's about where the smoke was coming from what should do?
Author:  Reed [ Fri Dec 26, 2008 11:08 pm ]
Replace the fusible link and find out why it shorted.
Author:  Joshie225 [ Fri Dec 26, 2008 11:08 pm ]
Fix the overload or short and then replace the fusible link.
Author:  Reed [ Sat Dec 27, 2008 8:07 am ]
Until you track down the cause of theblown fusible link, you may want to install a temporary circuit breaker instead of another fusible link.
