| don't know what its called (part) https://slantsix.org/forum/viewtopic.php?t=33005 |
| Author: | Bren67Cuda904 [ Sat Dec 27, 2008 10:06 am ] |
| Post subject: | don't know what its called (part) |
Its on the brake pedals push rod and holds said rod into master cylinder so catching ones foot under the brake pedal doesn't allow push rod to fall out rendering driver with no brakes as a result. New master cylinder didn't come with one and I am currently relying on brake switch to prevent this. Anyone have a part # for "it" |
| Author: | Bren67Cuda904 [ Sat Dec 27, 2008 2:40 pm ] |
bump |
| Author: | Eric W [ Sat Dec 27, 2008 2:45 pm ] |
Thought it was called a push rod retainer. I've heard of some guys using a piece of fuel line.....Probably not a good idea though. Or is it? |
| Author: | 64 Convert [ Sat Dec 27, 2008 2:45 pm ] |
I don't have a part number, but when I get a master cylinder that's missing that part, I've made a substitute out of a short piece of vacuum hose. Not perfect, but it beats nothing, and I've not had one fail yet. |
| Author: | Bren67Cuda904 [ Sat Dec 27, 2008 2:57 pm ] |
I am currently using a small peice of hose... and it bothers me. |
| Author: | emsvitil [ Sat Dec 27, 2008 5:37 pm ] |
If it's the little wire clip that fits in a inside groove of the master cylinder, you can make one from a paper clip. |
| Author: | Eric W [ Sat Dec 27, 2008 6:20 pm ] |
He is talking about the rubber piece that goes around the M/C end of the push rod. |
| Author: | makapipi [ Sat Dec 27, 2008 6:30 pm ] |
what if you email the manufacturer Raybestos? or Bendix, they might mail you couple retainers. |
| Author: | slantzilla [ Sat Dec 27, 2008 11:44 pm ] |
The retainer itself is nothing but a piece of rubber tube. |
| Author: | emsvitil [ Sun Dec 28, 2008 1:34 am ] |
Quote: If it's the little wire clip that fits in a inside groove of the master cylinder, you can make one from a paper clip.
Quote: The retainer itself is nothing but a piece of rubber tube.
Whoops, I was thinking of my trucks clutch master........... |
