It is currently Sun May 17, 2026 8:56 am
 Post subject: 3 speed floor shifter
PostPosted: Thu Dec 18, 2008 9:01 pm
I have a 1964 valiant 100 I just bought and I would like to put a floor shifter in it. the car has a slant and a three on the tree. does anyone have a suggestion on what shifter I should use?? It would be used as daily transportation.
To each his own (so what if I wanna build a 450 horse MPFI turbo /6 instead of using a V-8!)
PostPosted: Fri Dec 19, 2008 3:29 am
I suspect your choices will be limited but your bigger problem will be clearance in the hump for the shifter mechanism. I attempted to do this on a '62 more years ago that I care to contemplate and gave up in frustration. If you have metal working and welding skills it's doable but it is not trivial unless the '64 has a lot more room in the hump.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Dec 26, 2008 12:42 pm
Recommend the Hurst Super Shifter 3 followed by Hurst Indy Shifter. Bullet proof and choice of Hurst levers to fit your wants. There are several outfits that make floor manual transmission tunnels for the A-body. Need welding skills to install and must be a stickler for detail in making the cut in your existing floor pan. (Don't want to cut the transmission mount cross-member.) :shock:
You can't fix stupid. - Ron White
PostPosted: Sun Dec 28, 2008 8:24 am
Well I bought the hurst indy and there's no way that thing will fit. I cant believe theres not a floor shifter out there for this car :cry: The Indy is a universal kit but it wants to occupy the same realestate as the frame and crossmember. I believe I can make it work with some fabbing but dang I was hoping for a bolt in!!!! Did they offer a floor shift for this model new in a 3 speed??? If they did maybe I can get one of those
