It is currently Tue Oct 13, 2026 10:13 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Thu Feb 28, 2002 8:14 am
Hi Gang,
I'm going to replace my ignition coil and also install an electronic ignition system this weekend on my 66 Dart (/6 225). I noticed a small canister attached to the positive lead of the ignition coil. The canister is about the size of an M80 firecracker and looks very much like a condenser. It is attached to the engine block via a metal flange. I don't see anything in the forums or any of the wiring diagrams about what this part might be. Any ideas? Can I remove it? Thanks. Tom
kimpelt@pdx.edu
PostPosted: Thu Feb 28, 2002 8:19 am
It is a capacitor intended to filter engine noise from your radio. Some cars came with them from the factory, and some were added as a fix by the dealer or radio repairman. It's not needed for the car to run, but you might need it for your radio.
: Hi Gang,
: I'm going to replace my ignition coil and also
: install an electronic ignition system this
: weekend on my 66 Dart (/6 225). I noticed a
: small canister attached to the positive lead
: of the ignition coil. The canister is about
: the size of an M80 firecracker and looks
: very much like a condenser. It is attached
: to the engine block via a metal flange. I
: don't see anything in the forums or any of
: the wiring diagrams about what this part
: might be. Any ideas? Can I remove it?
: Thanks. Tom
lancer_41@excite.com
