| Ignition Coil: Odd Attachment https://slantsix.org/forum/viewtopic.php?t=3305 |
| Author: | Spazus [ Thu Feb 28, 2002 8:14 am ] |
| Post subject: | Ignition Coil: Odd Attachment |
Hi Gang, I'm going to replace my ignition coil and also install an electronic ignition system this weekend on my 66 Dart (/6 225). I noticed a small canister attached to the positive lead of the ignition coil. The canister is about the size of an M80 firecracker and looks very much like a condenser. It is attached to the engine block via a metal flange. I don't see anything in the forums or any of the wiring diagrams about what this part might be. Any ideas? Can I remove it? Thanks. Tom kimpelt@pdx.edu |
| Author: | Gary [ Thu Feb 28, 2002 8:19 am ] |
| Post subject: | Re: Ignition Coil: Odd Attachment |
It is a capacitor intended to filter engine noise from your radio. Some cars came with them from the factory, and some were added as a fix by the dealer or radio repairman. It's not needed for the car to run, but you might need it for your radio. Quote:
: : Hi Gang, : I'm going to replace my ignition coil and also : install an electronic ignition system this : weekend on my 66 Dart (/6 225). I noticed a : small canister attached to the positive lead : of the ignition coil. The canister is about : the size of an M80 firecracker and looks : very much like a condenser. It is attached : to the engine block via a metal flange. I : don't see anything in the forums or any of : the wiring diagrams about what this part : might be. Any ideas? Can I remove it? : Thanks. Tom lancer_41@excite.com |
