| Turbo 225 https://slantsix.org/forum/viewtopic.php?t=33071 |
| Author: | shane.colston [ Wed Dec 31, 2008 6:18 pm ] |
| Post subject: | Turbo 225 |
Thanks in advance for everyones advise before under simular title and any new advise. What pistons and part number do I need to use with a turbo. Also what cam is best for this set up. I will be using original 225 rods and crank. I will install the larger valves. How much should I take off of the deck and the head? Block is original with bore still 3.40. |
| Author: | Shaker223 [ Wed Dec 31, 2008 8:04 pm ] |
Shane, A lot of the answers you are looking for depend on your intended purpose and your goals for this motor/car (strip only, street-strip, daily driver...etc). Additionally, what is the budget you are working with? A lot of the cost depends on how handy your fabrication skills are. Let's say you have a 10-12psi boost goal then stock components (new replacements) are quite sturdy for the job at hand. I'd cut the head/block for at least a 8.5:1 comp ratio to help with the low speed non-boost situations and to make sure they are square. I'd definitely intercool it and add meth injection. The stock cam would be fine. If you wanted a new grind, go with something that has at least 114 lsa. The stock exhaust manifold will work as well. This should put an A-body easily into the 13's. Above is the cheapest route and actually very dependable. If you want to go faster things get a little more expensive really only as a matter of precaution. Custom rods, pistons, bigger turbo..ect. Unfortunately, there are not a lot of off the shelf speed parts for the slant six. Most items are cobbled together to make things "work". As an example, some have used the 198 rod and a turbo 2.2 piston with success. However, now with the new K1 7" rod it makes no sense to use a 198 rod unless you have them already. To purchase a 198 rod and then have it reconditioned it will cost as much as the new K1's (the 198 rod is 40 years old and heavier to boot). I believe the 2.2 forgings are starting to become scarce as well. For pistons, we have two manufactures who are willing to work with us. Brian @ Wiseco and Mike @ CP. I have Wiseco forgings @ $720 (piston,pin,rings,fitting & shipping). |
| Author: | Guest [ Thu Jan 01, 2009 12:24 am ] |
I totally agree with Shaker223 on all of his coments. Shane, if you have the budget and decide to build a higher boost slant6; please give me a call @ (949)567-9000. We can go over some details and I can give you a price quote Mike @CP pistons |
| Author: | JGTurbo [ Thu Jan 01, 2009 10:36 am ] |
Mike, This is off topic, but while I have you here I figure I'll ask. Can CP make custom pistons in orders of two or is four the minimum? Thanks, Jake |
| Author: | shane.colston [ Thu Jan 01, 2009 4:47 pm ] |
This will be a street/strip car, going into a 73 dart sport, i should be able to strip it to the wieght around 2800#. My fabrication skills are ok, I've got the tools and patience. Money is a differnt issue, Im trying to go with good used parts but I will spend the money when I have too. I was going with a 451 650hp route but with the cost of the engine build and all the mods for the car it would take $$$$ and 3 year project. I was told I can have all the fun and drive my car daily if I stay with the 6. I just want a 12 second car without nitrous and all the mods to the car. I am intrested in the 2.2 piston and the K1 rods. I thought that with 198 rod that my compression would be way too high. I was told by others that my compressor needs to be lower than 9:1. |
| Author: | Shaker223 [ Thu Jan 01, 2009 7:15 pm ] |
My car has run a best of 12.95@104mph @ 3365lbs-race weight. This was a 100% stock slant six (225) with 80k miles. The only mods to the engine were a deep pan and 340 valve springs. I used an 87 Buick GN turbo and 21 pounds of boost (intercooled and meth injected). In retrospect, I should have gone heavier on the springs. The intake was an offy 4 bbl and a home worked Holley 600 DP. See the below site for blow-thru carb mods. http://www.hangar18fabrication.com/blowthru.html If the motor is in the car and still running...keep it that way and do your fab & testing before building a "good" motor. Use head studs and you might have to o-ring the block depending on your boost levels http://www.youtube.com/user/Shaker223 |
| Author: | Guest [ Thu Jan 01, 2009 9:20 pm ] |
Quote: Mike,
Jake,This is off topic, but while I have you here I figure I'll ask. Can CP make custom pistons in orders of two or is four the minimum? Thanks, Jake Yes CP will do orders as little as 2. We will even do as little as 1. Pistons orders less than 4 do cost a little more but we will still do them. Please let me know what you need. Mike @CP |
| Author: | JGTurbo [ Thu Jan 01, 2009 11:47 pm ] |
pm sent |
| Author: | Backtobasics [ Fri Jan 02, 2009 9:21 am ] |
Great information in this thread. Shaker, do you have any more pictures of your setup? |
| Author: | Shaker223 [ Fri Jan 02, 2009 1:34 pm ] |
Flicker has a few pictures and so does the turbo forums but you have to register there. |
