| Will It Fit https://slantsix.org/forum/viewtopic.php?t=33085 |
| Author: | sixertrk [ Thu Jan 01, 2009 11:53 am ] |
| Post subject: | Will It Fit |
Would anyone know if a 1980 727 Torqueflight from a /6 would bolt up to a 65 273? Same bolt pattern? |
| Author: | SlantSixDan [ Thu Jan 01, 2009 11:57 am ] |
Nope, not even close. |
| Author: | sixertrk [ Thu Jan 01, 2009 1:27 pm ] |
Well, dang it anyway. Had a buddy with an unused 273 I thought I might swap into the ol truck while I worked on the /6. Maybe I can find an auto to go behind the 273. ......Thanks much!!! |
| Author: | SlantSixDan [ Thu Jan 01, 2009 1:30 pm ] |
You'd need a '66 transmission for that swap. '65 won't hook up to your truck's shift or kickdown linkages or driveshaft, and '67 won't fit behind a '65 engine. (the small-large torque converter nose change was one year earlier for V8s than for slant-6s, if I recall correctly). |
| Author: | sixertrk [ Thu Jan 01, 2009 3:06 pm ] |
I would never endeavor to bet against your recollection Dan, I'll take a look at the "parts for sale" tab. Thx again. |
| Author: | Ron Parker [ Thu Jan 01, 2009 4:58 pm ] |
Well I would bet against Dan but not on this issue he is Dan right. Thanks Ron Parker Do You Feel Lucky Dan Well Do You Coffee Lover |
| Author: | 6shotvanner [ Thu Jan 01, 2009 7:12 pm ] |
I like that one Ron,Dan straight he's Dan right |
