| Slant six rocker arms https://slantsix.org/forum/viewtopic.php?t=33091 |
| Author: | butch crawford [ Thu Jan 01, 2009 7:24 pm ] |
| Post subject: | Slant six rocker arms |
I installed a set of super six rocker arm shafts on a regular 225 motor - is the oil bolt the same? I want to make sure to get enough oil. |
| Author: | slantzilla [ Fri Jan 02, 2009 1:54 pm ] |
AFAIK, the "Super 6" arms are no different than any other motor unless you used a set of hydraulic arms. However, the later model shafts do use a stepped bolt in the back hole. If your 3/8" bolt went through the shaft you are good. |
