It is currently Mon Nov 23, 2026 3:17 am
 Post subject: On Carb Part ID
PostPosted: Fri Jun 19, 2009 1:20 am
Hi Guys - came across the following - Base plates differs on two further identical BBD's - on has LONG idle mixture screws - and the block they are screwing into is much thicker than the the other - mixture screws not interchangeable due to length
One has a 2 cast on it on has a 3... what gives? - is ther a guid somwhere with these partnumbers?
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Fri Jun 19, 2009 7:45 am
A "2" isn't a part number, and neither is a "3". There were variations in the throttle body casting. Some clear, sharp photos, mebbe...?
PostPosted: Fri Jun 19, 2009 7:22 pm
I have seen a minimum of 4-5 different style of idle screws in my BBD collection.
Users browsing this forum: Amazon [Bot] and 11 guests
