| 1982 /6 4 speed combo, OD or not https://slantsix.org/forum/viewtopic.php?t=33220 |
| Author: | Backtobasics [ Thu Jan 08, 2009 1:45 am ] |
| Post subject: | 1982 /6 4 speed combo, OD or not |
I have opportunity to pickup a /6 and 4 speed locally cheap. Was the 4 speed in these years ALL overdrive or only on the Miser packages? I am after the engine for the head, and if equipped, the 2 bbl intake. I would love to luck into a 4 speed OD, but I am not sure how to identify the OD units. The combo is bolted together, complete cost is 75.00. So in summary, were all 4 speed transmissions in 1982 Rams OD, and if not, how can I tell if it is OD? |
| Author: | DusterIdiot [ Thu Jan 08, 2009 5:04 am ] |
| Post subject: | Not all... |
Some trucks got the NP-435 4 speed... Before going into the whole diatribe, the truck A-833OD will have a longer tailshaft (it is similar to the B/E body A-833 boxes), you will need to look at the articles section and also look at some very old posts that Dave Clements wrote up on mods to get a truck A-833OD to fit in his Barracuda... FYI, -D.idiot |
| Author: | Backtobasics [ Thu Jan 08, 2009 7:17 am ] |
good info. I printed off the tech article, I will read through it and have my info ready. Either way, I am going to pick it up, as I want the spare engine, to build on the side. The trans is a bonus. |
| Author: | Rug_Trucker [ Thu Jan 08, 2009 7:46 am ] |
there is also an article in the tech archives on www.bigblockdart.com I printed that out on how to make the shifter work. |
| Author: | Backtobasics [ Tue Jan 13, 2009 2:40 pm ] |
Well, by all appearances, this is a OD transmission. The bearing retainer, which I presume to be the "snout" is 5.1? something, dirty. It has the longer housing, the article worked great to identify. I will take some pictures, as I have some other questions. |
