| Sealant on the Plug Holes? https://slantsix.org/forum/viewtopic.php?t=3328 |
| Author: | Mike [ Mon Mar 04, 2002 12:20 pm ] |
| Post subject: | Sealant on the Plug Holes? |
Hey guys, I'm assembling my motor and installing the aluminum spark plug bosses. Should I put some sealant around the chamfered edge that contacts the block, or do they seal metal to metal good enough? Thanks Mike mike.j.moser@boeing.com |
| Author: | Doc. [ Mon Mar 04, 2002 3:05 pm ] |
| Post subject: | Re: Sealant on the Plug Tubes? |
: Hey guys, I'm assembling my motor and : installing : the aluminum spark plug bosses. Should I put : some : sealant around the chamfered edge that contacts : the block, or do they seal metal to metal good : enough? Mike, The Aluminum spark plug tubes have a rubber o-ring at the top and seal directly to the head surface at the bottom. Be sure to remove the spark plug's metal gasket (ring) before sliding the plug into the tube. The tube acts as the gasket, no sealer is needed but I tend to use a small dab of anti-seize compound on those long reach spark plug threads. DD |
