It is currently Sat Jun 20, 2026 12:41 pm
 Post subject: tie rod end info
PostPosted: Wed Jan 07, 2009 3:38 pm
I don't have any of my books where I can get to them right now.
Question: tie rod ends, are they interchangeable side to side? Like I can get 2 outers, and 2 inners, and they fit either side? That's not what I understood from Tom Condran's performance handling book, but that's what it looks like from the NAPA parts catalog?
Thanks for the help. I hope to order them tomorrow.
PostPosted: Wed Jan 07, 2009 4:19 pm
The tie rod assemblies are made up of one RH threaded end, an adjusting sleeve and a LH threaded end. Same assembly fits either side of the car.
PostPosted: Wed Jan 07, 2009 11:12 pm
Sweet. That's exactly what I needed to know.
PostPosted: Thu Jan 08, 2009 9:33 am
It's also possible to interchange a heavier duty tie rod assembly for more durability, I forget what interchanges with what, though.
PostPosted: Thu Jan 08, 2009 10:28 am
You can use C body tie rods and adjusting sleeves on B bodys, don't know about A bodys.
PostPosted: Thu Jan 08, 2009 10:38 am
C-body tie rods fit A-bodies too. I think they are overkill myself.
PostPosted: Fri Jan 09, 2009 7:09 pm
They're probably overkill, but so are probably half the other parts I'm using for my A-body upgrade...
